Hi,
My TO-30 has a bit of slop on the left side were the arm goes into the housing.
I"ve read if it leaks to use grease and/or heavy oil.
Are the bushings difficult to replace?
Is it OK to fill it with grease?
I"m sure redoing the bushing is probably the "right" way to do it, but is using the grease method OK? Is it a short term fix or will I have more problems later?
Does replacement of the bushings require any special tools or knowledge?
Thanks,
Tony
Thanks,
Tony
