TO35 alternator installation
I'm changing from 12 volt generator to alternator (Delco Remy 37A 12 volt neg.) I have the alternator installed with the universal bracket kit however, having problems with the adjusting bracket. The orginal is to short. Does anyone who done a changeover supply me photo (s)of his TO35 Ferguson.
I think I need a longer fan belt and a wider pulley on the alternator.
I did tell you about the wider and smaller diameter pulley you would need to drive the Alternator when I emailed you last week with all the info. The belt you will have to see just how you finish up when the new pulley is fitted as not all conversions are the same, so what someone has fitted to their tractor may not be what you need. You will need to measure the Pulleys to see what size belt you need to fit around all 3. Make a note of the number of the belt when you do get one that fits....John
