TO35 clutch disengage problem
Modoc John
I continue to have problems with getting the clutch to disengage. Sometimes I can step on the clutch and at the same time stomp on the brakes and the clutch will release. Most times however, it won't release and I have to either shut off the ignition or pull it out of gear. Not a good situation, I.E. dangerous! Any ideas?
More than likely it's wet with oil from the rear seal, or if your lucky it could stand an adj. Probably need more info as to type of clutch, 2 stage or one.Park it on a downhill slope an after a week report back.
Sounds like oil on clutch,do you see oil dripping from bottom of bellhousing (cotter pin)sometimes the clutch will stick when disengaged. You might be able to spray break cleaner on flywheel after removing starter.
since I just adjusted and torqued down one a few hours ago, let me lead you to re-adjusting the pedal- and make sure the the bolt thru the pedal arm is super tight, if it loosen up over time, nothing will act right.- you've got a manual I hope?
