TO35 oil leak
Karman
Started leaking quite a bit of oil from weep hole under where the clutch is. Assuming this is from the rear engine seal. Can this be repaired by dropping the pan to access the seal or? Thanks
There are two possible sources.
1) rear engine seal - as you point out.
2) Transmission seal
I do not believe you can do it with out splitting the tractor. That said, I do not believe it is an impossibly hard task for a backyard mechanic. Though I will defer to other who have expierence to provide the help. John UK probally have a how to sheet on the subject.
Jeff
I just replaced the oil seal on my 51 TO20. Not a terribly difficult task but you do need to remove the pan and spit the tractor. The shop manual describes the process. I have one manual that describes rolling the front end forward and another that describes rolling the back end rearward to split. I found it easier to move the rear back.
However, I just started the engine this weekend after replacing the rear seal and I have oil dripping from the bottom of the bell housing. So mine might not be the best advice. I didn't think about the transmission seal. But, I drained the transmission and haven't refilled it, yet. So, I doubt it's coming from there.
The seals on the transmission shaft get worn very badly over time. If you don't drive over a sharp incline or "slosh" the hot hydraylic oil around it won't leak much. In the last year or so I changed my hydraulic oil from GL-1 to 15W40. when I did this, I got a lot of leaking through the worn seal. When I split the tractor to change it, there was very little of the metal flange that holds the rubber part of the seal. It had apparently been badly worn for some time, and when changing to an oil that was thinner at cold temperatures it "sloshed" out of the worn seal more.
There are two seals on the transmission, one is just a bearing holder on the lower shaft and the other is the shaft that goes into the clutch (where the bad seal is likely to be). You can change these fairly easily, but having a shop manual to describe the procedure helps greatly. You have to drop the lower shaft to get the upper shaft out. Once you get the upper shaft assembly out, the seal is inside the outer housing of the shaft assembly. There is a split ring holding the bearings and inner shaft inside the housing and it can be tricky to get out, but be patient, it really isn't that hard.
