TO35X cracked fuel line
Jeff Dix
The fuel line running from the injector pump to the primary filter has a crack where the steel line meets the brass banjo fitting on my 35 diesel. I"ve checked several places but can"t find a replacement line. Has any one ran up against a similar problem before? any advice on how to repair this line or where I might could get a replacement would be greatly apreciated.
Take the line and fittings off and go to a place where you can get hydraulic fittings or repair injection pumps, etc. they should be able to fix you up.
Take the line and fittings off and go to a place where you can get hydraulic fittings or they repair injection pumps, etc. they should be able to fix you up.
