Todays project
Lets take a bunch of stuff from different brands and time frames and see it they go together. What could go wrong! Todays ingredients are a 1940s tractor with aftermarket 3 point hitch thats a category 2. A new category 1 quick hitch. And 1 Ford 101 plow.
I got the hitch mounted and moved the plow in to hook it up.
At this point if your thinking that aint gonna work, your spot on! I dont see any way the plow will mate to that style of quick hitch. So I took it off and put the plow on without it. That was successful put what a pain in the back. And that is the whole point of this exercise, trying to make it easier to mount implements without needing to be a pro wrestler to do it. So now Im thinking that quick hitch it going to be returned and Im going to try this style instead.
Do any of you have experience with this type? Are they good or am I wasting my time? As always thanks for your thoughts and help!
It's easy for me to connect RM660 woods mower to 3 pt, it's on 4 wheels.
Everything else, I pick up with a chain connected to front bucket on terramite. Then it easy to move in place and connect to 3 pt while hanging.
I even tried making a fast hitch for older implements. Doesn't work as well as having things suspended on a chain.
No way could I connect my 900# ballast without it hanging.
I saw a you tube tractor stuck. I think in Russia. The tractor had a triangle on its 3 point hitch. It fit into another triangle that had like 1/4 by 2 flat metal welded at a angle on the top two edges. Must of had a couple of pins on the bottom. Seemed really fast to hook up and unhook. About cat 1 size. Anyone know anything about it?
I made my quick hitch so the grader blade can articulate a little.
I post a pic when I remove the mower at end of November and install grader blade for snow.
