Today's project
Don-Wi
While waiting for the rains to quit, I worked in the driveway today. 2 weeks ago when chopping hay, our Gehl 970 fell victim to their super stellar beater design. With a Meyer's wagon behind the barn that broke the gear box, we figured it was time to make use of some of the other parts.
I pulled the 3 beaters from that wagon and cut the ends off and welded on some plates we had made up with the bolt pattern for a Gehl beater. Replaced the one broken one and have 2 more that are ready to go for either the 920 or 970 when the next beater goes. The 920 already had one beater relaced completely with one from possibly an H&S model. The ones I made up are a direct bolt in replacement.
The donor-
The patient-
Believe it or not, the beaters from the Meyers wagon are only about 1 1/2" or so smaller in diameter from the lower 2 beaters Gehl used. The teeth are still within 2 inches of the apron chain so they should work just fine... Didn't have my camera or I would have taken some pictures.
Donovan from Wisconsin
Thanks for the kind words Larry. This year so far has been nothing less than depressing. I know it'll get better, but it still sucks for now. Last year this time work was uncertain and worked 40 hours max, with the occasional lay off. Also lived in an apartment just across town where it was easier to get away. Spent lots of time on the farm last season.
This season my wife and I have a house a few towns away, which means keeping up the outside as well as the inside, working 45+ hours each week (steady income is nice) and I just can't get away as easily. Not to mention having a little boy on the way in mid to late August.... Hard to keep everything going on the farm and at home at the same time.
Glad you had a parts box you could canibalize. If you run out of useable beaters, there's a machine shop near me that's making replacements. Looks original, but 2-3x as thick, actual tube rather than rolled up and pop riveted sheetmetal, and fully-welded teeth. Send me an email if you need his phone #.
I'm sure if I need some more to adapt we'll be able to find them somewhere around the area. Just wish we would have salvaged the beaters from our old Rex wagon and an H&S front end we had laying around. Woulda been able to make up some replacements and sell them....
The only snag we ran into with the one we replaced was that it was the bottom beater so it was attatched to the gear box, which meant a larger hub inside the tube of the beater with a bolt through it. The bolt was so rusty we just ground the heads off and slid the pipe over the hub. Doubt that bolt would ever try to walk out, and if it did it wouldn't get too far before hitting the wall of the pipe from the new beater. I think the rest of the beaters should be alright when we go to replace them when the time comes.
