Too weather checked?
edgerider11
Are these tires too weather checked?
I've run worse for years before they failed to the point of having to replace them. Big tires are big $$ so unless your livelihood is dependent on the tractor always being useable, just run the tires until they will run no more.
For what?
Seriously, you won't know until you use the tractor. Might also depend on how old they are, brand, etc. I would think that older tires from the 50's, 60's were made a lot tougher than new tires are today. I had a pair on my 1964 IH utility tractor that were probably the originals and were shot when I bought it in 1988. I used them for 10 years until the tube finally started showing through one sidewall.
I would say to give it a try and just not go anywhere too far from home or the barn at first.
Tim
If you are using the tractor for general purposes around the yard I would just run them until they dont anymore. If you are planning tractor rides or hauling wagons on the road, I would look for something better.
I bought a tractor with tires much worse than that. 30 years later it is still going and the tires are not much worse than they were.
As the others said, if for hobby use you will probably get quite a few years out if them. On the other hand, if they happen to have CaCl ''ballast'' in them running them to the point of failure is NOT a good plan!
Here's another vote to run them longer. Dad put brand new 23 degree Firestone's on his '51 M, ran them about a year and was opening up a corn field with the mounted picker and drove over a busted steel post, so he had the tire guy put one of the old tires back on, a 45 degree Gillette, I've never seen another tire by that brand name, it was on the M for 12 years and has been back on it another 50+ years and those cracks by the inside ends of the lugs will eventually go all the way to the tubes. I'm looking for a new pair reasonably priced. Tire prices follow oil prices, it's NOT the time to be buying tractor tires! What's sad the surviving Firestone looks about 2-3 years old even after 50+ years.
It's sometimes wiser to buy the better tire, it won't weather as fast and crack.
Depends. Are you going to hook to plow and run it 10 hours a day and put 600-700 hours on the tractor this year? If so - you need new tires. Or is it going to mow a little and maybe get 30 hours of use a year? If so those tires have 10 years left in them.
Run them ,
I wouldnt run them in road gear with two wagon loads of hay down a grade mind you .
Enough bar to plow and disc
You got fenders ,thats great.
Safety first
