Tool Definitions
SNAP-RING PLIER:
A special plier used to propel snap-rings from the part you are working on to the farthest, darkest, spider inhabited recesses of the garage.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting your freshly-painted vintage car (or boat or airplane) which you had carefully parked in the cornerof the shop (or hangar) where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench at the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh--....'
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Also very commonly used in the creation of bloodblisters.
CRESCENT WRENCH:
Used to prepare a bolt head for the application of pliers.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round-off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES:
Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
ACETYLENE TORCH:
Used almost entirely for igniting various flammable objects in your shop. Also handy for igniting the grease inside
the wheel hub out of which you want to remove a bearing race…and lighting a cigarette
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4:
Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR:
A tool, ten times harder than any known drill bit, that snaps neatly off in bolt holes thereby ending any possible
future use.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more
easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of
everything you forgot to disconnect from the engine being removed.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:
A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS:
See hacksaw.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt. It can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object you are trying to hit.
MECHANIC'S KNIFE:
Used to open and slice through cardboard shipping cartons delivered to your front door. Works particularly well on the contents of the carton such as seats, collector vinyl records,caustic/flammable/difficult to clean up liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing the work clothes of the person using the knife or anyone standing next to that person.
G%$-D*&^*T TOOL:
Any tool that you grab and throw across the garage while yelling G%$-D*&^*T at the top of your lungs. It is also, most often, the next tool that you will need.
SNAP-RING PLIER:
DRILL PRESS:
WIRE WHEEL:
SKILL SAW:
PLIERS:
CRESCENT WRENCH:
BELT SANDER:
HACKSAW:
VISE-GRIPS:
WELDING GLOVES:
ACETYLENE TORCH:
TABLE SAW:
future use.
BAND SAW:
See hacksaw.
PRY BAR:
HOSE CUTTER:
HAMMER:
MECHANIC'S KNIFE:
G%$-D*&^*T TOOL:
