tool question
rrlund
I need to pressure test an engine that's still in the tractor to see if the o-rings in the sleeves are leaking. I can make something to put air pressure to it,but is there a cap to go in place of the radiator cap that can be bought that has a valve stem or something on it to put pressure to it?
Foolish question I know,but it's just never been an issue before.
I had a buddy once make an adaptor that would screw into a spark plug hole and would allow attaching an air hose to it. I don't know where he got it from. It was quite handy when changing valve springs as it kept the valves closed.
I don't know how much pressure you need, but I've cut a bicycle tube and hose clamped the ends onto radiator outlets so I could find and solder leaks. I air it up til it's big around as a softball.
I just imagine you're looking for a lot higher pressure, but 15 lbs is normal on a car radiator cap.
Paul
A radiator pressure testor will have the adapters and the pump to pressurize the system. If you end up making something else don't go over 15 lbs psi.
Charlie M, just knock off the porcelin from a spark plug and braze on an air fitting. Been done lots of times and does not cost much.
There is a radiator pressure tester kit that you might be able to buy the seal for the top of the radiator out of.Try an auto parts store and see if they have anything in a catalog about parts for a radiator tester.
Also on a 855 Cummins diesel there is a plug,where the oil is pored in,kind of like a expanding plug for a freeze plug that you might be able to rig up,if it would be the right size.The plug has to seal below where the overflow pipe is.Also you need a regulator to only put about 15 pounds at the most on it.
Maybe one of those expanding freeze plugs would work if you could rig a way to put air in through it.Like a valve stem tapped for a nut and then screw an air coupler on to that,in place of the bolt in the middle.Or drill a hole through the center bolt and rig it to put a coupler on the end.
You could just screw a schrader valve in the side of the block (where the drain plug is) and then (if your pressure cap is functional)you would not likely overpressure the system.
Andy
Block off the inlet and outlet so you dont damage the radiator. Your radiator was not made for pressure. If you lubed the seals you wont have anyproblem.
Don't know that it needs to be all that complicated. I can just cut good sized chunk of an old innertube out around the valve stem,put it around the neck and tighten it up below the lip with a hose clamp then just put a little pressure to it. You'd think somebody would just make a cap with a stem in it,but there's probably a liability issue there.
Probably NAPA. Holding the valves up with air is sometimes used for spring and keeper removal and replacement.
I was taught to use air in cylinders to check for blow by---the air can be heard escaping into the crankcase. Check for cracked head as the radiator coolant will bubble like crazy. Check for burned valves by listening at exhaust pipe or carb if not injected. Cracked block would probably be indicated by coolant in the oil.
My compression tester has a quick connect fitting on the hose. You screw the end of the hose into the spark plug hole and just connect your air commpressor to the hose and it will push that piston to the bottom and you can remove the valve springs. I don't think this is what is needed for what rrlund wants to do. He needs a pressure tester for the radiator. Steven
Cooling system pressure testers are common in automotive use. I've had my Standt for years. Tool trucks have them on hand. Don't pressure test too much. Modern cars go upwards of 16 psi., but older tractors won't. I would put only a slight pressure on it and walk away for a while. Hope this helps. Gerard
