top link setting for bush hog
I'm wondering about the toplink setting when my bush hog is attached to the 340U. I level the mower at the height I want for cutting and then tighten the top link so there's no slack.
Does that sound right or is there another preferred (correct) method? As always, thanx for the help.
That is a pretty good way. I have been told that they operate easier if the front is a little lower than the rear.
Take off the top link and put a hefty hunk of chain there. The hog will follow nicely when you go through gullies and such.
I never hook a top link to a rotary cutter/bush hog just to mow. The only time I hook one up is to raise the cutter over hay bales I want to grind/chop up when I lower it over a bale.
The rear wheel does everything I need to keep the cutter level.
I can't understand how the posters below can run with no toplink. They must be hogging smooth fields. I know my 5' John Deere brushcutter sometimes catches a mound of dirt,a rock or anything sticking up with the front and then it wants to tip forward but the toplink keeps the hog from tipping right over on me.I use a Massey 135. And I adjust it pretty much the same as you do.
I think a chain might work in place of a top link as long as it couldn"t drop down enuf to hit the PTO shaft.
I built this 3-point set-up for my Bush Hog; it was a trailer type originally.
I copied the top link attachment point from the ones I see at TSC. It is hinged to allow a certain amount of movement as the rear wheel goes over rough spots.
I must have a funny rotary cutter. The front is open to the blade. If and when the blade would come in contact with dirt I raise raise the front up high and stop. I do fit my fields as level as possible before seeding.
i run a chain also as a top link onthe bush hog. also, run the chain thru a piece of 2 inch pvc plastic, about a foot shorter than the top link. it will keep the chain out of the pto shaft, and allows the tail wheel up and down movement when crossing a swale so you dont bend the mower frame or top link.
(quoted from post at 22:43:59 11/05/10) I can't understand how the posters below can run with no toplink. They must be hogging smooth fields. I know my 5' John Deere brushcutter sometimes catches a mound of dirt,a rock or anything sticking up with the front and then it wants to tip forward but the toplink keeps the hog from tipping right over on me.I use a Massey 135. And I adjust it pretty much the same as you do.
02
What model JD cutter do you have?
On most 3pt cutters I've seen the the 2 straps(the ones designed to pickup rear of cutter if center-link is attached) going from mast to rear of cutter are not strong enough to not bend if tall wheel comes a foot or more off the ground.
Most 3pt cutters if operator chooses to attach toplink aren't designed for toplink to be only tight enough to get tailwheel off the ground in the fully raised position but not tight in cutting position. This allows tailwheel to follow contour of the ground as it was designed to do.
i like the solid top link also, keeps the bush hog level for me, but find that it's only good for my 5 footer, 6 footer is built to light for solid link if kept tight
Ive been through this before. The 6' light duty bush hog I had was terrible, it was slightly bent from running it solid on a top link. When I hit mounds or went through low spots the tractor moved, bushhog stayed stationary and tail wheel had all of the pressure on it. The one I have now (bushhog 3008) is very tough and the whole tongue (3 point) is telescoping so it moves often when going over rough terrain. I'd set bushhog to cutting heighth with 2 point, then put in a piece of chain to make it level, this should fix any problems.
Boy, I guess I'm pretty lucky. I just hook up and go, including the top link. My tractor has draft control that works off the top link. Go through a dip, and it will pick it up accordingly. I have a 6 foot Bush Hog.
(quoted from post at 09:58:39 11/06/10) What's to keep that mower from pivoting up if you hit a rock or root? It might land on your head!
I still think if you hit a rock or stump that the flimsy little straps on the 3pt will not keep the cutter from flipping against the tractor.
