Top radiator hose
SKYLER53
Any suggestions on the easiest way to replace the top radiator hose on MF 135, Perkins gas. Got it almost on with gas tank still on. Won't go
any further. How does the gas tank come off? Only see I bolt in front on the left side? Two in the back. Any input greatly appreciated.
Can't be of any specific help, dont know the machine. But If you can get it started, how about a little liquid dishsoap to lubricate the inside of the hose and give 'er a good push?
(quoted from post at 22:14:09 08/14/17) Any suggestions on the easiest way to replace the top radiator hose on MF 135, Perkins gas. Got it almost on with gas tank still on. Won't go
I don't believe you would need to take the fuel tank off to replace the radiator hose. I also think if you would lubricate the hose it would go on easier. I have that same tractor and I've had the fuel tank off twice. There is a bolt on the front right hand side as well. If you'd like to e mail me I'll try to help. [email protected]
