torq values
How did you check clearances and tolerances without a service manual?
Those head bolts maybe a use once and throw away type. Particularity if that head was removed due to a gasket failure.
If the valves and seats were ground the compression ratio will now be 1 or 2 points lower. Cool weather starting will suffer.
Which Mitsubishi motor? There are dozens of models.
