Torque question
jachamar
Can someone be kind enough and tell me the torque for the 3 bolts going from the rear plate to cylinder block in a 2000 Diesel 1971?
Thank you in advance
3/8 bolt, probably around 25 foot pounds or so. It's certainly not critical, all it does is retain the plate until the engine is bolted up. Newer engines only came with one bolt.
Most the time I am not that picky,but behind the plate is a cork gasket around the crankshaft.That's the reason i am a little concern.
Anyway for now I put 15 for holding up.
