Torque Spec for JD R injector keepers
Scc,
The August 1954 Field Service Bulletin lists for the R:
Delivery Valve Holder: Bosch 34-36 ft lbs, Bendix Scintilla 80 ft lbs.
I assume the "delivery valve holder" would be the injector...
Thanx. I was thinking around 50 #'s and we seem to be near that. There is a copper washer at the end of each injector and to deform it could cause some problems.
Duane:
The delivery valve is not the injector, rather it is located on the front of each injection pump. That's why there are two values, for each brand of pump. Folks either damaged them by over-tightening, or allowed them to work loose because they didn't torque them enough.
I think if no stated torque value is found, I would opt for a standard torque table value for that. My '70' Diesel books only says to tighten "securely".
Hello Frank,
Thanks for the clarification - there are no other values given in the FSB for injectors, so your bolt size scheme is the torque method to use. I've never owned a Deere diesel.
