Torque specs 3364a
Working on a power unit motor 3364a and need
torque specs for replacing head gaskets and
wondering if you are to torque them after
the motor heats up and cools off and if you
use spray tac or anything on the head
gaskets
Book shows 170 to 175 ft lbs on 5/8" studs and 130 to 135 ft lbs on 9/16" studs. The 9/16" studs are only on a diesel i beleive. Re-tork after 100 hrs according to moline manual. Also you will need a crows foot for a few of the nuts by the water manifold on left side of unit and I believe some of the nuts that also hold down rocker arms. Cold valve clearence for gas is .012 intake and .028 exhaust. If diesel .012 intake and .017 exhaust.
