torque specs
jeff te48
Dropped the pan, spun the main drive gear roll pin,so I'm putting the rebuild kit in,don't like the aluminum big gear that comes with the kit I think I'll press the factory steel off the shaft and see if it go on the new shaft, anybody else do this? Pros/cons on the alum. gear?What I could use is the Torque specs for the oil pan bolts and oil pump to block bolts for a 120 continental motor {1948 TE20] as always....Many Thanks...jeff
Bolt pump & front main bearing cap in position using shims removed between pump housing & bearing cap. Torque to 85-95 lbs.
Maybe I over looked it but I did not see any specs for torquing pan bolts. Put bolts in tighten good, if there becomes a leak tighten more. LOL Good luck Richard
