Torque value
37 chief
Need to torque my F150 rotors to 190 lbs. My torque wrench only goes to 150 lbs. Can I just go to 150, and a little more and, use red lock tite? Stan
Yes you can but I wouldnt use red . I would use blue in case anyone without a torch ever wants fo get it apart
That's what I did and all has been good.
I don't recall using Locktite though, I might have, been a couple years.
Do the instructions call for Locktite?
180 ft-lbs is a bunch. I would torque to 150, then switch to a breaker bar and give it a little extra.
To get 180 ft-lbs on an 18 inch breaker bar will require at least 100 lbs of force. I don't think you need to worry about over-torquing. I would not use loctite in this application.
> If I stand on a 1 ft breaker bar, I would get 190 #ft.
And possibly a broken nose when you slip off, George. I don't want to see you or Stan hurt. The rule is always PULL on a wrench.
Mark,
I'm an experienced jumper. 4 ft cheater bar, 190# = 760 #ft.
Still jumping at 72. Haven't slipped yet.
(quoted from post at 06:54:47 11/29/21) > If I stand on a 1 ft breaker bar, I would get 190 #ft.
So when it slips off it hits you square in the teeth.
Doesn't matter how you do it, there is some chance of injury. All you can do is be as careful as you can and learn from your lumps.
150 is still 150. A 'little more' amounts to what?
How about this: Get a 3 foot piece of pipe and put it over a breaker bar. Then get a pull scale and apply 63 to 64 pounds of pull to the end of it. Then you will have an accurate measurement of the torque. The whole purpose of the torque value is to insure adequate tightness and to apply it evenly. A 'little more' will not do that.
Adding loctite to the mix will NOT get your rotors 'tighter.' It will only serve to make them harder to get apart the next time you need to replace them.
(quoted from post at 10:20:06 11/29/21) 180 ft-lbs is a bunch. I would torque to 150, then switch to a breaker bar and give it a little extra.
He wants 190
If wanting 180 using an 18 inch breaker bar, would you not need to apply 120# vs 100#??
Get a 20' length of one inch pipe, cut off one foot and use it as a snipe. Hang a ten pound bag of sugar on the end and voila, job done (if what I read here is accurate). Then take the 19' pipe back to Home Depot and return it. They'll never guess that it's short and if they do, tell them that's why you're returning it. Just one other way to get the job done .....
Measure the length of your torq wrench, make extension the same length that your wrench is that your wrench will fit into.
Works good. Mine does.
My wife's dad is 83. He broke his hip last night around 8pm. He lives alone and we offered to make some improvements in his home for his safety. Or let him come live with us. He refused everything we have tried to do. He is having surgery today and we have decisions to make for his care now. Be careful George. Make good decisions we don't want you hurt.
Ten months ago I, at 85, fell and broke my hip. I live alone. While in hospital and therapy, 8 weeks, my offspring changed all kinds of things around my farm to help. Some I appreciated, some I didn't. Anyway, back to living alone at home.
Over the past 64 years I've somehow managed to not hit myself in the mouth with a wrench. But they say there's a first time for everything. First, though, I'll need to have my right arm surgically modified so it's even possible.
I should know better than to do math first thing in the morning. I must have been thinking of Metric Inches, where there are ten to a foot.
