Good evening guys n gals.
I have a blasting business that uses a Dustless blasting unit and a Tow behind Ingersoll rand 185 that I purchased used.
It's been serving me well for almost 10yrs but have a problem that happens every few years. When i turn the key to run, then start she fires right up, but then when you let go the key goes to run and it dies.
The first time it happened I replaced what looks like the main relay to a NAPA one, and that seemed to fix it and about 5yrs later the same thing is happening again. Pulled the relay and brought it to NAPA. NO numbers or markings on it. They went back in my purchase history for my account and said it was superseded by another one (that they didn't have for some reason having to do with this Coved crap..) well, found another one with the same plug ends and ...nothing.. Same crap.
The diagnostic lights show "High compressor temp" ??? it hasn't even run for more than 10sec. How can it be overheating already?
I HATE wiring and although there isn't much in respect of a harness, they seem to paint EVERYTHING that grayish-tan color and it's kinda hard to scrap off the paint to see the colors of the wiring, let alone 20yr old mesh loom. It's gotta be something simple, because it would fire right up and run great.
I've spent hours and hours googling the past week to find pretty much nothing.. Well, that they sold out the tow behind compressors to Doosan a while ago.
Usually one can find EVERYTHING on Youtube, but even doing a fluid change/re-fresh came up with nothing. I've downloaded PDF files that are supposed to be 'user manual' but are pretty vague on their description of parts. AND NOT A DAMN THING on a troubleshooting flow chart of ANY KIND!
There is a 2-prong plug at the front bottom of the compressor, but jumping that or unplugging it made no difference. Other than that sensor, I don't see any other that would give a reading on the compressor.
I called Ingersoll rand's place here in the Memphis area, and they gave me to this one equipment servicing business that works on them.
It seemed that they didn't want to divulge any info unless I were to bring it in for $120-150/hr, and I'm sure a minimum time..
Since I was doing a fluid change, I purchased 3gal of the compressor oil/coolant that they recomended and changed that. ..THEN i see under the pass side panel that I/R calls for ATF- Dexron-IV. Do I have to drain out the 2 gal of their fluid and replace with ATF? (don't have the name of it right now.) But it's clear and a lot thicker than ATF. Just don't want to blow up my compressor. Can't afford another one.
I do have a 2.5gal jug of Amsoil universal ATF that I could use. But I just spent $120 on theirs
And lastly.. changed out the big square glass fuel filter, but didn't fill it with fuel. SO, thinking 'maybe' could help. I turned the key, it fired up enough to suck all the fuel in the lines before the filter could fill up. NOW, have to bleed the fuel lines now. I know how to do that, but is there a bleeder screw on the Standadyne pump somewhere? It's a B1 DB2 4972 pump for a 4cyl JD diesel.
And in trying to fill up the fuel system, I was turning the engine over in 5-10sec bursts to run the little lift pump all to have the battery start to die..
As you might tell, I'm getting pretty frustrated over all this, when It was running just FINE a few months ago..
Sorry if It seemed i'm jumping around, It's the ADHD thing, and just be happy we're NOT talking on the phone lol..
In my searching, I've found MANY others that ask pretty much the same thing but don't get an answer or response, and the thread just dies. (like 5-12yrs ago dies!)
SO, if any of you guys that work on/service them can offer up some help, it would be GREATLY APPRECIATED!!
Then on my end, I can log on with my phone and add pictures to help any others that might have the same issues.
