Gary Mitchell
Rolling weight on a hard surface like that doesn't take that much to make then roll . The fun is stopping it. And in the later 70's they showed a pickup pulling a 4 bottom plow in the field turning furrows too.
I always wanted to try that with my 78 K20!Rolling weight on a hard surface like that doesn't take that much to make then roll . The fun is stopping it. And in the later 70's they showed a pickup pulling a 4 bottom plow in the field turning furrows too.
Yes the pulling isn't the problem the problem come in when you have to stop. Seen to many times where some one loads up a trailer way over what the tow/car/truck should handle and end up in a wreck due to not being able to stop and most of the tiem the out comes is very badRolling weight on a hard surface like that doesn't take that much to make then roll . The fun is stopping it. And in the later 70's they showed a pickup pulling a 4 bottom plow in the field turning furrows too.
I've never seen it. It's usually the ones that are properly loaded and secured that end up in accidents in my experience.Yes the pulling isn't the problem the problem come in when you have to stop. Seen to many times where some one loads up a trailer way over what the tow/car/truck should handle and end up in a wreck due to not being able to stop and most of the tiem the out comes is very bad
I have an AC book with a picture of an ad they ran about their largest tractor pulling a freight train. Can't remember the model- maybe 7080? 7060?
Maybe there are just more of them on the road.I've never seen it. It's usually the ones that are properly loaded and secured that end up in accidents in my experience.
Why? Maybe the ones with the grossly overloaded trailers go slower? Maybe because they look bad, others drivers actively avoid them? Maybe the ones that are properly loaded get a false sense of security, and drive too fast? Maybe because they look good, other drivers get a false sense of security, and drive too close? I dunno.
Maybe the key is to look janky, drive like it's janky, but have everything in tip top shape, and properly secured? Kinda like shipping stuff... I notice I have fewer problems when the box looks like it's been kicked around.
The false sense of security effect is real.I've never seen it. It's usually the ones that are properly loaded and secured that end up in accidents in my experience.
The local feed mill near me used a Farmall 460 gas to move the rail cars years ago.
The local feed mill moved "freight trains" with tractors for years. First with an IH 806, then a Ford 8000 or 8600. It was pretty hard on the tractors.
I usted to push up to 5 loaded RR cars with a 1010 JD industrial tractor and loader. Lift the loader up to the do not push sign on the ladder. Put it in 1st about 1/2 open. And let it eat. Always moved them. Carried short oak 2x4's to throw under the wheels. Then cranked on the brakes. There were 2 of us.
