tractor cab
I can't give you a definitive answer, and I doubt anyone could. You may well be the first person in recorded history to want to do this. Massey has made so many different models...
Anyway, I did some quick research and it appears that the 565 and 590 are in the same series of tractor. Whether that implies a common mechanical base, or just model numbers coinciding with HP output, I could not tell you.
Both tractors spec out the same two transmission types, an 8-speed and a 12-speed with multipower. That's promising.
The pictures of the tractors look promising as well.
Do you have the 565 close enough to you that you can go and sit in it and inspect it to compare it to your 590?
I have no idea what those tractors are. Get a good parts book for both models and start by compairing part numbers to see if they are the same. If the basic cab is same but mounts are different could you make the mounts?
