Tractor front wheel - JD B
ChrisLSD
I have about a 1950 JD B and on one front wheel the bolt holes are all out of round and wallowed out - so the wheel moves on the hub - any easy fix, or would it be better to get a different wheel?
Not worth messing with- get a new wheel. Save the old one....next time maybe the rim gets damaged- then cut the old ones apart and use both good pieces to make a good wheel. I"ve bought damaged ones at auction for as little as a buck- made good wheels out of them.
If it is the common 6 hole rim they are a dime a dozen so I would just replace it. I keep a couple spares on the place just so if I have a blow out etc I can just change and go
