Tractor Hours in a Year
Briar Hill Brittanys
Location
Near Jasper, MO
Just wondering how many hours a tractor acquires in the course of a year, I typically run up 200-300, this year 287. Mostly mowing, square baling a few acres, firewood collecting, etc. It's a JD 5045, the only horse in the stable.
In Feb '93 I purchased from local JD dealer a used '91 JD 4255 that had 2847 hours showing on speed/hour meter in about 1.5 yrs of use. That tractor now has 2,000 hrs with 10,000 hrs of use hidden by numbers rolling past 00000.0 for a total of 12,000 hrs The hours that I put on it was while custom farming/baling hay. It hasn't been used much in the last 4 or 5 yrs due to my retirement.
1969, bought a IH806 with 1500 hours and sold in 1998 with over 13000 hours. The last few years I had it, it pretty much was used for auger work. Engine was never opened up for anything, only split once for a clutch and still had original TA. Had an offer for it I couldn’t refuse even though it was not for sale.
Hours per year might vary with the type of hour meter used on the machine.
I suspect electric hour meters tend to record higher hours than mechanical hour meters because most electric hour meters simply record the number of hours the engine is running regardless of the engine speed while mechanical hour meters are geared to record hours run at rated RPM. Depending on how the machine is used a mechanical meter could record 10 percent lower for a tillage tractor or a combine that mostly runs at full RPM while a mechanical meter might record 30 to 50 percent lower for a yard tractor might that rarely gets up to full RPM.
Maybe some of the newer electric hour meters already compensate for this?
Put one on a grinder-mixer on a dairy farm grinding and mixing feed for 250 cows, 7 days a week and you might be surprised. one of my customers has at least 10 tractors and more than one has over 10,000 hours.
It depends on how much snow we get each year. In bad winters I might put a couple hours or more per day. The past few years I don't think I've put on 20 hours between 4 tractors and a skidsteer.
I boought a one owner 806 off a farmer i meet at a sale that was a low hour one with only 4700 hours . It was a 66 year model and i fixed it up to as near new cond. as one could and planned on keeping it . My buddy laid a paint job on it that out did his best work . It made the cover of fast line . I had no intention of selling . Then some guy showed up and asked i kept telling him it was not for sale and he could go find one at most sales for 45-6500 . He just kept bugging me while i was tryen to finish up a customers tractor . So i figured that is i throw a way out price on it he would just go away , so i said 8750 and he goes Oh and turns and walks out the door . 20-30 min. later he comes in with his wife a and said how do you want the check made out . I came back with cash only no checks no credit cards CASH . He sends his wife to the bank and she comes back with cash. I was once again looking for and 806 as they were getting hard to find . I ended up buying one off and auctioneer friend over east a real rag with org faded paint nasty chain marks on the fuel tank sheet metal from when the picked this tractor up after it was broken in half from a tangle with a semi . oil leaks everywhere red dirt packed in every nook and granny and it was a narrow ft and a early model that someone changed the remote levers on and a fast hitch , and new rear tires . It came from the south from some sale Ed had worked and he lived in Bunkerhill W. Va . It was UGLY then and worse now . Could it be fixed up to look new , Yep but we ain't ah going to do it . It runs like a scalded dog and it has become the go to tractor for just about everybody in the neighbor hood as ya never know where it is . Of all the I H 06 and up series that i have bought and sold this old RAG has the best steering of all and steers like a Deere . Why and how come i have no idea . If and when needed ya can back up to the 5x16 720 plow and go to plowing in sod your in third low T/A in the high side in corn ground you can run forth low high side . Ya can drag the 18 foot disc once ya put the duals on . . the only job it fails at is round baling due to the fast hitch bundle dragging wind rows . the best part is NOBODY has bugged me to buy it .
Probably about 100 hours per year average for each tractor. There's probably 20 tractors around here, - everything from an old 60 to a 5520 and three 450B forklifts. In high season most everything has an implement attached so it saves a lot of time hooking stuff up.
