(quoted from post at 19:03:04 09/20/22) Had just rebuilt the transmission, made four passes around a large pasture with a brush hog and the tractor lost power to the rear wheels. Unhooked the brush hog and the tractor could barely pull It's self back to the garage .
he mower seemed to run fine and the tractor after unhooking the mower was still sluggish.(quoted from post at 17:40:39 09/20/22) So, lost power is what we say when the engine gets real weak, and aputters or idles so slow it cant hardly pull the tractor around.
But I dont think ou actually mean that?
I think you mean the engine runs fine, but the rear end of the tractor is not moving much.
Like the clutch is slipping, or a shaft stripped out and isnt transmitting the power to the rear wheels?
Was the mower still spinning, powered, by the pto, or did both the pto and rear wheels lose power?
Going to take a little bit here to get us all on the same page, so Im just trying to throw some ideas out and see if that helps you.
Paul
(quoted from post at 19:47:58 09/20/22)he mower seemed to run fine and the tractor after unhooking the mower was still sluggish.(quoted from post at 17:40:39 09/20/22) So, lost power is what we say when the engine gets real weak, and aputters or idles so slow it cant hardly pull the tractor around.
The mower was still running and were getting little to no power. Unhooked the mower and the tractor could barely move. After rebuilding the transmission, I've had it out several times testing it and it went through the gears fine and had plenty of power. Yesterday, I hooked the mower up and mowed four times around a big field and that is when it lost most of the power to the drive wheels.
Paul
(quoted from post at 08:00:15 09/21/22)
AHH. I think he said this: Unhooked the brush hog and the tractor could barely pull It's self back to the garage .
