Shetland Sheepdog
First job was to replace one of the block heater elements on my 5610. (the old one was leaking). Man! I didn't think we were ever going to get the screw backed off far enough to get the darn thing out of the block, but we finally did! The new one went in "slick as a Smelt". Replaced the coolant with new stuff, and added a pint of "cavitation inhibitor". The new "anti-freeze" was blue in color instead of green, so I read the jug, and it appears that it already has the additives to prevent the corrosion and pitting issues! So, the tractor is now double protected!
Second job was to find out why the starter "throws out" on Brother's 5000. We pulled the starter, (with loader on tractor, and without removing fuel filter). We dis-assembled the solenoid and cleaned it, then re-assembled. All appeared normal and correct. Installed starter on tractor and tried it. It still throws out after about 1 revolution. That's fine when tractor is warm, but not when it's cold. We took a look at the ring gear while the starter was out, and it appears that the starter drive is not pushing out far enough to fully engage the ring gear teeth. We are suspecting a weak solenoid, but as I type, I'm wondering if the problem could be the feed that energizes the solenoid? (tractor still has original key switch and wiring). Any thoughts in this from the experts appreciated.
Just as a note here: we used 3/8" drive socket, extension & ratchet to get the back bolt on the starter!
TIA, Dave
TIA, Dave
