Tractor Motor Oil
EDW
Hello Folks. The Tractor manual for my early 70's calls for SE-30 motor oil. That oil is really hard to find anymore. Can someone suggest an alternative? Thanks in advance.
I'll second the 15-40 diesel oil.
It's a closer match to the old flat tappet engines. Anything with CJ, CK, etc will work.
Modern gas automotive oil is designed more for roller cams and emission compliance.
I use the O'Reilly's brand 20W-50 in all my tractors but the 1935 JD-B and the IH584. Last I knew one could get 30W oil at O'Reilly's but now days not needed since the making of oil has improved a lot since your tractor was built so a 10W-40 or other such oil will be just fine
Diesel oil in a gas engine?? I was always taught that was a no-no. Also non-detergent oil if there is no oil filter
I have run the same 1540 fleet diesel oil in all my (10)gas tractors,Gas combine(jD95),pickup,grain trucks;motorcycle,ATV;lawnmower...everything for 40 plus years. That includes my 4 diesel tractors,too. Have never had an oil related failure.One oil for all. Keep it SIMPLE.
You don't say if your tractor is gasoline or diesel. Based on the SE oil spec, I'll assume it's a gasser.
The newer oil specifications are supposed to supersede the old ones. So the current SN spec oil should be fine. Many of the diesel oils also carry gasoline ratings (e.g. SJ, SK, SM or SN), so they should be fine as well. But not all diesel oils carry gasoline ratings, so you should check the label first. Will the oils that don't carry gasoline ratings hurt your engine? Probably not; one reason the diesel oils don't carry gasoline ratings is they have more zinc than the gas-rated oils. That's because zinc tends to wear out catalytic converters, which your tractor doesn't have.
As for running 15W-40, that should be fine, unless you want your tractor to start easily in sub-zero temperatures. If that's the case, I'd suggest using something thinner, such as 10W-40, 10W-30 or even 5W-40.
