tractor problems
johnny ga
5600 ford 233 engine tractor would only crank with help of either. and would only idle and not rev up. installed new tank new petcock new filter installed new injectors and went thru injector pump with new seals and o rings. still needs either to crank and will still only idle help
Cranking means battery or wiring and either will do nothing if it cannot turn the engine over as you are saying will not crank.
your problem sounds like a worn pump,have your pump put on a test stand and you will see what the problem is also have injectors checked
