tractor quit running why?
m buckman
ok why did my kubota diesel quit running when I was cutting grass. I was mowing along when it just like i turned off the key. Then I turn the key and it would start then die, start and die start and die, I did this about eight times then it started but had no power when i gave it gas it whould die then start back but with no power again. Then it started and had power then die. Then it started and ran fine. I finish mowing. Could it have been water in the fuel?
Would think the filter unit would have trapped any water in the bottom before you got in trouble. Does it have a drain at the bottom? Can you drain out a cupful or so, and see if there was water in it? Dirty filter, plugged fuel line, air in fuel line, all could cause same symptoms.
