tractor restoration
b wood
I have recently sandblasted my tractor,and havent had the chance to prime it which should have been done shortly after,Ihave noticed due to the high humidity it is starting to rust especially the frame should I spray an etched two part primer on it any suggestions appreciated!!
Hit the tin with a product from your local body shop supply, called "Metal Prep". It's a phosphoric acid. Then apply the etch primer on the tin, Epoxy primer on the cast.
Gordo
