Hello every one, I have a 1952 Ferguson TEA 2085 that has seized up. I was moving brush to a dump site with my trailer and it was working fine for 5 loads. Stopped & shut off the tractor to load up and when I tried to start it up to take the load away the tractor would not start. I am able to tow it in neutral. When I engage the starter it makes a small click but will not turn over the engine. The cable going to the starter gets warm when I engage the starter. The tractor is now negative ground and has an alternator. When I try to tow it with the tractor in gear it just drags the rear wheels in the gravel and will not turn over. I am unable to turn the engine over with the crank handle. When this originally occurred, there were no noises, clunks or other bad sounds made when I shut off the tractor. Since I didn't hear anything when I shut off the engine & the oil & other fluids are all at their proper levels, I don't think that the engine is seized but cannot determine this for sure. I tried to remove the starter but I am not able to remove it after taking out the bolts. It is firmly in place and will not budge. I tried prying it off, hitting it with a hammer & block of wood to try to loosen it but was unable to free it up or remove it. Is it possible that the starter has seized up on the ring gear? I have read that this occurs with other vehicles/engines. One site suggested putting a socket on the front nut and turning the engine counterclockwise to free up the starter. I was wondering if anyone has had this happen, how the issue was resolved and any other suggestions for resolving this problem. Any help/suggestions would be appreciated.
Thanks,
Ron
Thanks,
Ron
