Tractor Seperator
Tractors have wheels and you only have to move one section. A dolly with blocking and a screw jack would save you over $800 and no welder required. I have seen some use a trailer jack bolted to the one section to move it and it's adjustable, might need a bracket fabricated though.
The latest ones I made. Since most things I do are green I just cut some old 3010 frames that had the holes for the taper bolts wallowed out since the other holes fit the green frames but the plan is if something red ever shows up just build a different mount if 6 inches. Scale to size most probably don’t need one for a 4640. You also don’t technically need the wheels but it’s nice to be able to move half a tractor wherever you want.
