With regard to tractor size, I know that implements cannot be too big for a tractor. However, what about using implements where the tractor is actually capable of handling larger instruments. For example, using a 6 foot bush hog when the tractor is large and strong enough to handle a 12 foot bush hog. I know my HD Silverado can pull up to 15,000lbs but I can pull as little as I want without issue also. The only danger I could think of is potential damage to an implement but if a mower is a 540rpm and the tractor does that then what’s the downside? Is this a situation where bigger is ok up to a point and if so, what’s the point where it’s not ok?
