I have a "late model" New Holland Workmaster 120 that was purchased with the thought that I would eventually do larger-scale hay production (including some custom work). As it turns out, my circumstances have changed and I am doing small squares with 60 year old equipment that is paid for, and no longer believe I "need" a 120hp tractor. I would rather spend my time doing other things than haying for other people.
I think reality is that I might be doing 35-60 acres of hay which could potentially include round bales in the future. A round baler uses plenty of hp, but a disc cutter and wheel rake do not approach a need for 100 PTO horsepower. What would be an appropriate-sized tractor this this kind of thing, and would I need the 120 for putting down fertilizer (for example).
Can anyone help me make a case for keeping a 120hp tractor? Will it break implements that require a "minimum" of "only" 50hp or less? A lot of farmers have multiple tractors (lower power, middle, and higher). I just did hay using a sickle bar mower, rake, baler, and tractor that are all 50-60 years old and maybe older (sickle bar mower). All adequate and pretty reliable (baler is getting more reliable with use). I love the Workmaster 120--it is comfortable and very useful (loader, hay spike) but am finding that for small square bale hay work an open-station tractor (instead of cab) is preferable and wonder if it is worth finding a smaller cab tractor for everything else or if I'm likely to take too much of a loss on the 120 to make it worthwhile.
Thoughts?
Thoughts?
