sbaugh1964
My 2N recently had a tune-up, new harness, new plugs, distributor and coil, ignition switch and resistor (less than 20 hours of use since tune-up). Everything was working fine without any issues but I went out to start it after a short break (3-4 hours) and it won't start. There is no clicking, just silence. The battery is a 6 Volt and is fully charged so the system is charging the battery. At this point, the only thing I can think of is the starter (cut off) switch which was replaced 3 years ago is bad. At the time the cutoff was replaced, I was told that the cutoff switch can go without any warning, is this true? Is there a way to determine if the starter is bad?
Regards,
Stuart
Regards,
Stuart
