Tractor starts without key
Waterbug
To35 model 1958 running good started to slow down then shut down, would not start back up, read battery .36 volts
Went to jump off battery hook all cables up went to put cable on tractor positive tractor tried to start up turn over with out the key in the ignition or starter button pressed in, no idea any help thank you , my first post have used this forum in the past with good results.
A weak or depleted battery can weld the starter
solenoid together and cause it to
start on it's own. Had it happen
several times myself.
