Tractor Talk
I have a D17 Allis C. When I put the hand clutch in neutral the tractor will still keep on moving unless you apply the brakes very strongly. What might be the cause?
It's not a hand clutch as such. It is a two speed unit AC called a power director. It does not have a true neutral position. Low is to the rear and high is forward. You can hold it between them to stop the tractor without using the foot (engine) clutch,leaving the pto and hydraulic "live". Handy when baking or "bush hogging" in heavy going as a couple examples. It is common to have to use the brakes to hold the tractor, especially when they are cold, while you hold the lever in the sweet spot between the ranges. I have 3 D14s and a D19, that is the way they all operate. Do not think you can put that in neutral and have the tractor stay put even if it does stop at times, only have it between ranges when you are in the seat and working the lever.
If you don't have the Operator's Manual you should get one. You should also considering getting a Service Manual.
(quoted from post at 02:57:12 12/19/19)
___________________________________________________
Speaking of manuals, my D-17 manual refers to it as a Power Director Clutch.
In the lubrication section it reads:
POWER DIRECTOR (Hand Clutch).
Under the section: POWER DIRECTOR CLUTCH (Hand Operated), it says: "The forward position provides the high range. The center position is neutral and stops power to the drive wheels. The rear position provides the low range."
So....there is a "true neutral" position.
I have a WD, a WD-45 and a D-17.
The manuals for the WD/WD-45 refers to it as the "Transmission Clutch"
This "hand clutch" serves the same purpose in all the tractors with the added feature of providing two ranges in the D-17.
Like the others have said, it is normal to have drag especially in cold weather.........that drag will diminish as the oil warms up.
You are correct Brian. My wording is wrong. I agree the manuals do refer to them as Power Director - (Hand Clutch). It does have a neutral detent so yes it has a true neutral position. I have adjusted the 4 tractors I have and with the lever in the neutral detent they still won t set still a good percentage of the time, unless at least slight brake pressure is applied. Maybe there is more play in the linkage of mine than others causing some of that along with the drag; but that is why I said it doesn t have a true neutral. I should have said, in my opinion, it doesn t have a true neutral, as I feel a true neutral would be able to set on flat ground without trying to drive/drag, as they will when the transmission in neutral. These should not be used to try to achieve that level of neutral condition, in my opinion.
All that aside, to the OP s question the drag when in neutral is common. Once I got used to using a power director it works quite well doing pto work, for me at least. Being able to easily change ground speed, stop travel, or ease into something, like a bunch of hay in the windrow when baling, is handy.
