(quoted from post at 14:19:07 11/14/22) Recently saw this fluid at Lowe's. I know there's been discussion about different trans/hyd fluids but don't recall anything about Mag 1. Looked it up on Google and the specs list it as suitable for Ford/NH ESN-M2C143A-D and others. It is a premium universal tractor trans/hyd fluid, but still not sure it is okay for my Ford 8N.
side from the 303 stuff, which is the subject of a class action lawsuit, most tractor fluids saying that they meet M2C134 are ok.
I am going to step in it and say some things about moisture and oil grades. The argument over the amount of water that can be in solution is moot. We all agree that too much moisture is bad and too much isn't a heck of a lot. 1% water content is off the charts for all but the PAG lubricating oils. For any reasonable hydraulic fluid for these tractors, 300 ppm (0.03%) is about the maximum amount of water than can be in solution. Don't believe me, read this, Figures 8 and 9. https://www.machinerylubrication.com/Read/28697/humidity-saturation-limits
Bottom line is that the oil will eventually be contaminated by water condensing from humid air. If you don't live in the Mojave desert, you have to change it annually. If you could get a non-detergent oil, and if there is a place in the sump where water can collect without getting churned up, it might be better to use that and drain the water periodically. I would want a smaller drain plug for that.
You can remove the water, but new oil is cheaper than the equipment needed to dry it. https://www.sealingandcontaminationtips.com/remove-water-hydraulic-fluid/
I may be new here, but I am not new to motor vehicles in general. I grew up with a 9N, but in 10 years and a total of 2-300 hours of use, maintenance was not much of an issue until I left home when my father finally did work on it without me. It always started and ran without a hitch when I was living with it. Hence I have many years and few hours of experience using but not maintaining a 9N tractor. 50 years later I am finally getting my hands dirty on a tractor. I have overhauled 2 cycle Saabs, Corvairs, a Renault 16, a 78 Honda and dismantled a '28 Rolls engine, so I am not new to engines.
These tractors were designed to survive the oils available in 1939. That is not to say that those oils are good for the tractor, rather the tractor is resistant to the relatively poor quality oil available at the time it was built. The Ford flat head engine with its looser tolerances and lighter loads tolerates SA better than a newer, more highly stressed engine. SA oil is not good for any engine. Those were the days of 3000 mile oil change intervals, leaded gas, ridge reamers and surviving even 100,000 miles without a complete overhaul was impressive. Until the 70s, we just accepted the inevitable wear that the available oils were incapable of preventing. Older engines are better served by modern oils.
This is a list of oil grades over the years:
https://www.thelubricantstore.com/motor-oil-classifications
The typical description is "SC - Obsolete, not suitable for engines built after 1967." implies that it is good for engines built prior to 1967, which it isn't (unless you set your sights low enough). It should probably just read 'Obsolete - superseded by SD in 1967." It was only good enough for earlier engines because it was the best available at that time.
Back to hydraulic fluids. Tractor oil is good enough, but generally has friction modifiers for wet brakes and clutches that are a compromise between wear resistance and clutch friction. Cat has some heavy duty hypoid gear requirements that are not well served by oils with friction modifiers. I will continue to use a reputable tractor oil that claims to meet the long obsolete M2C134 spec, while recognizing that the claims to meet both M2C134 and TO-4 are mutually exclusive. I am sure there is a better alternative, but I'm not ready to bet the tractor on a hunch. See:
https://www.castrol.com/en_us/united-states/home/heavy-commercial-vehicles-oil-and-fluids/hd-focus-newsletter/engineering-solutions/understanding-the-differences-in-gear-oil-specs.html
This is a good general description of gear oils:
https://bobistheoilguy.com/forums/threads/gear-tribology-and-lubrication-part-i.57856/#post-729255
