I have an IH 574 Gas tractor that runs great but recently developed a problem where it will not stop running when I turn off the key! It will, however, stop when I disconnect the electrical line to the fuel shut-off solenoid. I checked the ignition switch and that appears to be OK. Once the tractor has stopped, there appears to be no battery drain. I checked the voltage at the fuel shut-off solenoid with the ignition key in the run position and there is no voltage -- the solenoid appears to be getting it's power from the alternator rather than a switched battery supply. Does anybody have any idea what is happening and how to fix it???
