Hello fellow tractor buffs. I wanted to see if I could please get some more info on this tractor. Like year model etc. Also what do you think it is worth? I was told it would run but hasn't for years. Thanks for any help you could give. Sorry this is the only pic the guy sent me. I know you can't see much of it!
Looks like an SC to me. I wonder what the "bracket" is for that it looks like it's backed into. So much "junk" around it, you can't get a good look at its back end. Looks like it has its cultivator brackets still on the rear axle, but most people in our part of the world took the fenders off when the cultivators were on.
SC Case pre-1950...must be a 49 as it has hydraulics. That was the last year for that style fender. There is a fella in Tenn. looking for the cultivator brackets and levers that are on this tractor. $500 as it sits up to $1000 if running would be a ballpark on price. They are about 25 horsepower and hand clutch operated....good solid tractors in the day.
For me, scrap price unless he can prove it runs or unless you or someone you know has a need for a bunch of the parts. If your hoping to turn a buck, good luck.
It is a CASE SC, likely around 1950 vintage. The SN plate should be down on the panel that the gauges are in. It seam to have most of the cultivator lift attached. Do you have the rest of the cultivator?? The tractor alone if it runs is worth around $1000-1500. The cultivator may fetch another $500.
Loren
Here is what it can look like after a little elbow grease (maybe more than a little) and some flambo paint. Mine is a 1945 model SC. It is like the one where I had my first driving lessons.
After seeing a JD A, 1945 model, slant dash, only average condition with weathered rear tires, electric start, fired right up, sounded good with no smoke, high bid was $500, at auction, no sale. Owner wanted $1500 for it. If it had been closer to home (60 miles) I probably would have bid on it, to no avail. Doesn't look good for the old tractor market. If the Case doesn't run, probably $300 max.
How much is he asking RB? Don't worry, nobody is going to run out and buy it before you have a chance .... ha!
