JR. FRYE
By now you can tell that I am the new kid on the block: ok what is the difference between a
WD45 and a D-17 and can i still us it on my farm
plowing snow with a end loader on it,drilling post holes,pulling a bush hog and any thing that come's to my mind.and is the D17's easer to find?
I am sorry I am a pain. But I have to start some where. MANY THANKS JR FRYE
Basically the D17 is the updated WD45. They share the same engine (with upgrades) but not much else. D17 can be found with 3 point hitch which would probably be handy for you. Expect to pay a little more for a D17 in comparable condition.
Not an AC expert by any means, BUT, why are you so dead set on a wd-45? The D 17 is an improved WD 45. D 17 has a high-low transmission while the WD 45 has only a hand or foot clutch and 4 gears. Look to the left side of the page for tractor photos and you can see the difference between the 2 of them. D 17 is newer, should have power steering, be handy if you want a loader on it. WD's are hard to get on and off of and they will kill your back riding them if you do much work with one. Drawback is the AC snap coupler unless you get a 3pt conversion for it. Unless you find a late model D 17, they are one way hydraulics, can be a problem if you want to use some newer equipment or a log splitter. Do you have an AGCO dealer nearby? It gets to be a pain having to drive 40+ miles to get parts. WD 45's were/are a good old tractor, lots of power for their size, but many more user friendly units are out there. MY opinion, Chris
Biggest difference is the Power Director- a hand clutch that gives high and low in each gear, plus the middle position is a clutch, so you get live pto and hyd. WD & 45 have live power with the hand clutch, but not a high and low range in each gear. About a quarter million WD and WD45 were built, (WD45 starts at SN 146607), vs 68 thousand D17. D17 had a bit more power and weight, and later ones had the 3 pt. hitch option, instead of the Snap-Coupler system. Beginners should stay away from the diesel versions, either tractor. Not all that dependable.
I have a WD and use it for plowing snow,works great.It will push a lot of snow,so far I have been getting by with no chains,I have a set but never put them on,I live in West Michigan so at times we get a lot of snow.I also use it for pushing dirt to
I do not know if you have bought either one of these but we have a loader on a d-14 with a hyd pump for the loader on the PTO. (about 350$) and worth every penny. If I was going to recommend a bulletproof tractor for a loader, this is it. From 1959 to 2002, this was our only loader and we had dairy & hogs.
Easy to get parts for too!
We also had a wd-45 and a straight WD. I would not recommend either one for a loader. Rough ride and not at all a d-17. DO NOT BUY EITHER ONE IN DIESEL. Not very good diesels.
Yes,neither one is comfortable to drive,but that said,the D17 is MORE comfortable than the WD45.
There is a lot of improvements in the D-17 and more hp at around 52HP and the WD45 is 45hp. D-17 has a high low type power director which also gives you live PTO. Also a lot more common to see a wide front on a D-17 then it is to see on a WD45. I own both and hands down I prefer the D-17 over the WD45
never drove either but have been on this forum awhile and read what others have said. The D17 is a nicer newer version of a WD45. A little more horsepower. They made a lot of both tractors although more of the WD45's were made. I hope this helps. The AC forum might be more help. And parts for both will be easy to find.
