BarnyardEngineering
- Location
- Rochester, NY
If your trailer axles were at or under 14,000 combined, and the trailer is sitting nearly level, you're okay. About the only way you could possibly be overloading an axle in that situation is if you have a slab of lead sitting directly above one axle. A distributed load like cattle or just about anything will spread evenly across both axles.I ran both truck and trailer on scale with truck full of fuel then just trailer 2 axles on scale and then just truck by itself subtracted truck weight off to figure out how much trailer weighed and then done the same except for truck by itself loaded to figure out how much weight was on trailer and how much was on truck don’t really have a way to do each axle individually but everything’s gone good the last 2 days
Now just got to get the idiots at the sale barn to not try and run everything up in trailer and shut the doors
The axles are not going to turn into horseshoes at 7001lbs...
