Trailer brakes not working
I have a 14000 gvw dump trailer a 2012 the brakes stopped working took the hub off shoes are still good I checked voltage at the rear of the truck and got around 8 volts.ive never dealt with trailer brakes before so I'm kind of winging it anymore have any suggestions where to start looking thanks Rick
Are you talking electric brakes ?????????? If so If not post back
If you're reading 8 volts when any current is being drawn, when its supposed to be near 12
THERE MUST BE A BAD/LOOSE/CORRODED/RESISTIVE CONNECTION Such will drop voltage causing poor or no operation
OFTEN ITS A BAD GROUND CONNECTION
Rear trailer receptacles, be they 6 pole or 7 pole or the small 4 or 5 flats, can go bad or wires are missing or connections are bad
If you're talking ELCTRIC BRAKES so many times the wiring is broken or loose or there are shorts
If you have electric brakes and an electric brake controller THOSE UNITS CAN GO BAD or the input wiring to them is at fault
If you have electric brakes and too small of wire was ran back from the controller that can cause voltage drop
If there's a short in the trailer wiring or any brake magnets or their wiring that can cause voltage drop
CHECK THE GROUND CONNECTIONS
Nuff said for now as we dont have much info to go on so see if the other fine gents can add to this and suggest other possible problems
John T
8 volts could be right depending on where the brake power is set. Always start at the plug and work back. Start with a battery and hook to the plug and see if you have brakes. That will tell if the problem is in the truck or trailer. Once you know that work from the plug out til you find the issue. You will get lots of advice here telling you to check this or that and they willl all be right for the most part. The problem with that is you can bounce past the issue, especially if you have more than one.
(quoted from post at 08:04:35 09/02/20) Thanks for the replys I'll see what I can find out
Electric controllers are also rated for number of axles with brakes. Be sure your controller is rated for the number of axles (or more) you have.
Bad ground is 99% of brake problems. Check all grounds , especially trailer to truck. Look at the magnets , do they appear burned(blue black color). A burned magnet loses its magnetic ability , if so replace them. Check that the activating arm moves freely and is not rusted tight, so anti sieze on the moving parts is important. LISTEN :Get someone to push the brake pedal down in the truck while you listen by the trailer brake...You should hear a hum. This is the magnet grabbing the drum face. If there is no hum the brakes are not activating so start running checks ie) bad ground , broken wire,burned magnets, seized activating arm and so on. The brake controller will give different readings depending how high or low it is set, but I think 8v should be activating the magnets. When I do trailer brakes I pull the drum and look.If the drum is rusted the brakes aren't working, if the drum face is rusty the activating arm is not working, if magnets are bluish in color they are burned , if none of this then the adjusters are seized and need to be freed up or replaced and the shoes set up with slight drag on the drum. Also over the years found that if magnets shoes etc are bad its cheaper to buy the entire brake assembly and eliminate a lot of mechanical time changing each component. Four bolts and a wire connection and you have the new assembly on and ready to go. Good luck
(quoted from post at 05:18:32 09/02/20) Agree with Jon on this.
just went thru this on my trailer. We replaced all 4 backing plates still had no brakes on the right side. Turned out we ran a jumper wire to add more Voltage to the right side and we now have all brakes in working order.
Doesn't the controller vary the voltage according to how it is set and how hard you press on the brake? Constant 12v would lock them up i would think.
(quoted from post at 06:27:43 09/02/20) I have a 14000 gvw dump trailer a 2012 the brakes stopped working took the hub off shoes are still good I checked voltage at the rear of the truck and got around 8 volts.ive never dealt with trailer brakes before so I'm kind of winging it anymore have any suggestions where to start looking thanks Rick
A simple thing I have been doing for years that saves me from chasing trailer brake and lighting problems.
3 and blow
Plug the trailer cord into the tow vehicle then pull it out.
Now blow out the dust and dirt from both plugs, a puff of air from your mouth is adequate.
Repeat this 3 times then plug it in and check your lights and brakes.
More times than not this will result in everything working as it should.
What kind of connectors are on the wiring?
If it's original wiring they probably used the fold over "cut through the insulation" connectors. Those are worthless! Even if crimp connectors were used they may be loose and corroded by now.
Look all the connections over closely. The only sure connection is soldered and shrink wrapped, sealed with liquid electric tape.
If counting on the ball hitch to be the electrical return path , you are being overly optimistic .
Needs a working "ground" system .
Rick, I bought a new PJ in 2007 from a large dealer near Indianapolis and they gave me a can of cleaner and said be sure and use it as most problems are from contact loss. My truck has integrated brake controller and have 3 times when truck showed trailer not connected, and once on road from tractor show, stopped and give both truck and trailer plug a shot and all was well. I pulled a different trailer one day and had to do same for it. My trailer sets behind barn next to woods lots of spiders, bugs of all kinds and junk off of trees. I keep a can in shop and the truck.
