Trailer Hitch
Anonymous-0
I have a wood chipper the hitch is only a 3/4 in. bolt, and nut to attach it to my turck receiver. Is this legal? There is a lot of weight up front on the chipper. There is a Ford V 8, at the front end and the weight of the chipper. If it is legal I will probably just leave it. It just jerks a lot when I pull it a round. I just got this unit, and hoping to make a little extra money when the mowing and discing are through for the year, which is just about now. Stan
I am not if it is legal or not, but it wouldn't cost that much to convert it to at least a 2" ball. It will take all the jerking away and it will trail alot better down the hi-way.
I think I'd use a hitch pin and not a bolt, but I see noreason for it to be illegal. Puttuing a ball on would definately take up a lot of the jerking, or you could buy a shock-absorbing receiver hitch like I did for my truck. Cost was only about $45 and I use it for pulling all the farm implements.
Donovan from Wisconsin
Make sure that your hitch and Pin are all the same size that will eliminate the jerking. The pin is a better stronger way to tow your chipper that's why they use it. Any farm supply will have the correct pin for you. $5 to $10 bucks.
Walt
If you are pulling with a bumper hitch that is your problem I would not pull anything with a bumper hitch . Get you a hitch that is at least Cat 4 then you can pull without worry . Some of the jerking is in the bumper .
Do you have 2 safety chains? Last time I read the rules it said you need a pin with a keeper on it & 2 saftey chains.
Your bolt with nut meets the basic item, but in a lawsuit it would be a lot easier to say _this hitch pin_ that was sold to me as such broke, so the accident is not totally my fault, but the fault of the _hitch pin_ manufaturer..... Otherwise you gotta prove your bolt was strong enough, etc. etc.
--->Paul
OldMax
I disagree with you on that. I pull a 16' car hauler all the time with just a bumper hitch and have never had a problem. Have not once had to tighten the bolts on the bumper or anything. I will agree that some of the older trucks did have a problem with the bumpers coming loose. I have not on my 99 F150. Safety wise I believe my bumper is just as stout as a reciever hitch.
Gary, read the weight restrictions stamped on your bumper. If you are exceeding them you are leaving yourself wide open for a lawsuit, if you are ever in an accident, whether it involves failure of the hitch or not.
Aloha,
Is it possible to post a picture of the hitch?? The hitch that you are describing doesn"t seem right.
Mahalo,
doogdoog
