trailer preservation
ghunziker
I have a wood deck trailer which is outside most of the time. Would used motor oil work to treat it or would this make the deck slick? Thanks for any help.
5 gallons first time. Two gallons second time.
All soaks in. Going to apply 3 coat this summer when things dry out.
Not slick
SV,
I gave my boy two oak 3x12x5ft boards off an old workbench. He scraped off the old grease/dirt and put it in a baggie. Said he wanted to remember how my old workshop smelled. I kid you not.
I have been doing it for years. Not the least bit slick or greasy. The wood sucks it right in. I would let it weather for 2-3 years first.
Forgot to mention, I do this on a HOT and SUNNY day, my trailers are never slick. The diesel mixture will help the oil penetrate the wood
I have been buying mistake gallons of deck stain at the local hardware store for $10. Colors are sometimes weird, but it works. I get about 2 years out of a gallon on a 16 trailer.
Tim
(quoted from post at 14:36:26 08/14/21) Can you put the used oil& diesel mix over Thompson water seal? The wood has been treated numerous times? Thanks
Don, I had a third gallon of Thompsons that I put on part of a trailer and followed two years later with oil and the wood sucked it right in.
I've had used oil on two trailer decks and I'm done with it. It does soak in but not all the way, it will make it slicker, at least for awhile. You will not want to sit or lay on the deck, if you want to be clean. The boards might not stay wet but still oily enough to collect dirt and transfer to clothing. The oil treatment might last a year depending on conditions.
