Trailer ramps
I'm going to build new ramps for my deckover trailer thinking about three inch angle by a quarter inch thick by seven foot long would the angle be heavy enough .Rick
I don?t have the answer to your direct question. Sorry.
The steel ramps on my deck over were to heavy for my back. I called Landsport in Sturgis. They built an aluminum set to my needs, actually a standard offering.
I love them. Just another avenue.
Paul
Rick,
My 14k implement trailer has ramps made of about 3 inch angle. They weigh a ton, but they are hinged with spring assist to lift them.
My 10k dump has ramps made of same angle. They are about 6 ft long and weight more than I want to lift, so I made a pair of ramps out of 2x12x10 #1 yellow pine with two 2x4 attached to edge. They weigh about half the steel ramps, longer, wider and are strong enough for Kawasaki mule. I rarely use the ramps on dump trailer.
George.
Go on line and put in trailer gate lifts. Here are several. Supposed to let a ten year old kid lift it.
Most of the used gates I see like that are bent, and they rattle when going down the road. I would prefer aluminum ramps that slide in and out from under the trailer frame.
What are you going to load? As a general rule on trailers if 3/16" thick won't hold, go taller rather than thicker. Angle is not a great structural member as they hold a lot less weight per pound that channel or tube. With an idea of what your loading I could maybe help more. 7' is quite long too and you may be better with a leg half way.
The ramps on my goose neck trailer are made out of 2 inch channel iron with 1/4 inch by 2 inch angle iron cross pieces. The trailer was used to haul a Case back hoe. Heavest thing I load now is a 6200 lb tractor. Ramps are heavy but I do not worry about them bending or breaking.
A little more info is probably necessary to give and accurate answer. Gvw of the trailer and what you plan to haul will be factors.
(quoted from post at 18:38:42 10/31/19) I would use channel it would give a lot more support, I made a set like that on a 16000 lbs rated trailer and did not have any problems.
Yes, the reputable trailer builders use C channel for their ramps. There is a reason for this.
I love living on the edge. Still not dead yet.
My ramps are longer, wider, smooth ride and lighter.
Ladder ramps that came with trailer are shorter, steeper incline, and a little scary because of the bumpy ride.
I use ramps to haul Kawasaki mule, 4010, and sometimes lawn mower. I wouldn't want to attempt loading a mower with ladder ramps.
The best thing I did to my ramps was to weld a piece of pipe across the end that sets on the ground.
My ramps are channel with angle iron steps the ramp is set on a piece of channel that goes across the rear of the trailer.
When the wheels of the tractor would hit the ground end of the ramp it would raise the front of the ramp up out of the channel : ( the pipe trick fixed that : )
