Trailer tires
I have a 14000 gvw dump trailer with 16 in tires been having problems with tires blowing out and noticed there all made in China can anyone recommend a good tire made in the USA or is that a thing of the past
Rick i learned a long time ago that any TRAILER tire as they call them are pretty much junk. For what you tryen to do you need a 14 Ply tire . I run a 12 ply on my 18000 # Goose neck , it came with 8 plys , yea that worked well. Back in the Hay days of coal bucketing we hauled extremely heavy and ran really fast and the brand new East Dump that i bought did not make the first day with the GOODYEAR trailer tires as i blew one on the first load , Next day another one blew and the next two let go . That is when they all came off and i stepped up to second line steering tires and ended my tire problems even loading as much as 60000lbs on two axles . Now that i am down to LITTLE trucks and trailers i have been having really good luck with Master Craft tires as i was having problems with the GOOD FOR A YEAR. I ran Good Years for many years up till like 2007 when i needed tires on the War Dept's Durango , it came with Good Years from the factory and we got just under 90000 miles on them So i put what I THOUGHT was the same tire back on and in less then a year we were having belt separation one tire after the other and we were replacing four tires a year . The guy i get tires off of told me that i needed to switch and he put the Master Crafts on then i put Master Crafts on the truck then the trailer . when i do haul my old ways will never change as i still load the wagon and haul a lot more then i should but tire problems don't affect me .
I been getting them at the local tire shop just never paid attention where they were made at all four tires are from China
I will search tomorrow for 14 ply tires see what I come up with. I've blew two tires and broke two belts in the last three years
Putting LT tires on a trailer solves the problem for most people because the number one reason for trailer tire blowouts is to much speed and LT tires are rated for highway speeds.
ST tires still have a stronger sidewall than LT tires so if weight is your problem LT tires will not help.
People think just measuring the GVWR and loading the trailer to max is good.
Trouble with loading max weight is you need to worry about what each tire is hauling.
For 7000 lb trailers not a problem.
Go ahead and put LT tires on it and forget it.
But when you get into 10,000 14,000 lb range you better make sure you have 12 ply ST tires
You better make sure you keep your speed down
And you better make sure the weight is distributed evenly over all 4 tires.
An LT load range E tire is rated around 3,600 pounds, so over the rates capacity for a 7k axle. And they will be less likely to give the kind of trouble he is having.
Load range E barely gets him in the ball park.
He loads a pile of dirt with 8000 lbs on one side and 6000 lbs on the other and now 2 tires are over weight.
I would be looking for load range F 4000 lb tires.
And finding a load range F in a narrow LT tire may be a problem.
Like I said I would agree with you if we were talking 3500 lb axles.
Put some LT tires on it and be done with it.
But 7000 lb axles are really a different story.
One reason I hate 7000 lb axles.
In my opinion I feel 14k trailers should have tri axles or at least 2 dual tire axles.
3500 and 4000 lb on each tire should be left to semi's that can handle that kind of weight.
I run Firestone Transforce LT tires on my 14,000# bumper pull trailer. Usually have it loaded to close to 11,000#'s not including the trailer which is right at 3000#'s. I run byway speeds with it and have never had a tire failure with it. You have to take into consideration some of the weight is also on the pickup tires so your not caring the full rated amount on the trailer.
I don't know where they're made but we've had good luck with Hankooks. I don't remember the size on the tire but they're the same as a 7.50-16 and 14 ply. Have them on a couple of 24' stock trailers and a20' car hauler all 14000# trailers. They are also on three dual tandem trailers that regularly haul in excess of 20000# whether they should or not. By the way with farm plates we can get by with quite a bit down here. Tony
Well if he loads like that he is overloading the axles too. The load range E tires are rated for more than his axles are rated for so he is as safe with the tires as the axles. If he over loads the trailer the tires will hold up as well as the rest. Putting heavier tires that are trailer rated tires won't help him with his problem.
I bought my last goodyear tire two decades ago. They never lasted long enough to wear one out. Just my luck with them.
Me and a couple of guys I know who haul a whole lot more and more frequently than I do have switched to running LT radial tires. I take the old ones from my one ton and they go on the trailer.
Now I've noticed there is a place selling 19.5 wheels that have the older size eight lug pattern found on most heavier axles. Now you can upgrade to 19.5's and buy real commercial tires.
Besides all the other replies-proper air pressure is very important. Too low will cause tire overheating and subsequently blowouts. Mark
I put Hankooks on a car this year after a lot of shopping. If their work tires are as good as their smaller tires, they ought to go the distance. Will be going on my PU when the current wear out.
14 ply trailer tires are worth every penny. I have a 28' Load Max gooseneck with 7k axles. Ordered factory with 14 ply tires. Never one bit of tire issues. I travel 70-75 MPH loaded. It has been loaded heavy more than once and none distance at speed when it's hot out. Usually try to keep it fairly legal weight wise doesn't always work that way. China 14 ply trailer tires are still going to hold up better than US made 10 ply, ST or LT series truck tires.
(quoted from post at 09:12:13 06/28/20) I have a 14000 gvw dump trailer with 16 in tires been having problems with tires blowing out and noticed there all made in China can anyone recommend a good tire made in the USA or is that a thing of the past
You've got lots of responses re using 14ply tires. My opinion is the same. I put Sailun S637-s 235/85R/16/G on my 14K car trailer after using their 17.5/H-s on my dump trailer. I've had no problems, and believe they're a good tire for the money. I didn't know Hankook made a similar tire. We used to use them on lowbeds and believed they were the best tire for the money at the time. Today my preference would be a US made tire, but they'd probably be twice the price.
