Trailer Wiring Harness
in-too-deep
Location
56676
Looking for this harness for my BigTex
tractor hauler. It is part of a modular
sealed harness that is original equipment.
It goes from up in the gooseneck where the
breakaway battery is, down to the chain
box. Bigtex parts department is clueless
and I can't find anything online. The
letters "USAH" are molded into the end.
Anyone know who makes these or who
supplies them? I would bet most trailer
makes use the same harness. Thank you for
helping.
I've had good luck with etrailer.com, but I didn't see anything like your harness when I took a quick look there.
Is the disconnect needed or could you just remove it and wire direct?
Unfortunately your dealer is clueless. Contact the manufacturer and tell them make and model from the data plate on your trailer. I replaced mine a year ago.CM
Try one of the light companies like Grote or others. Also could try some of the semi trailer dealers. I have bought replacement parts like that from them for trailer tail lights on my trailers they had a whole harness for each side that pluged into the main coming back from the front. I know if you were to sue the seven pin plugs grote has complete harnesses for semi trailers and might even have the shorter front one you want.
