Tranny Fluid Change
howdy1960
4 gals kerosene, 2 qts ATF, couple containers cheap rubbing alcohol, a few low speed laps around driveway, pull plugs....what a pretty pink 'milky' mess, look in filler hole. YEAAA!!!
So much cleaner in there. HOWEVER, now I know where allllll the gaskets needing replacement are ~eye roll~ Both trumpets, both lower arm connection points, already knew right axle seal, at least sump gasket is holding (so far) ~laughing~
Thank You for the help :)
Thought about doing that however have limiting factors like a outside in dirt/mud/snow work area, money for parts, cherry picker and cribbing and other misc issues. Gonna start getting parts over the winter since need to pull top cover (lift wont stay up with clutch depressed) and tear apart in spring. Again Thank You for the help.
Norm
