trans ,hdy,rear end
DODGED75.
from reading forum i take it that these all use same fluid in one big unit and if i want to change it what amount and what kind hyd oil motor oil ?
The manual for your tractor says to use straight mineral oil. You can still get it, but it's expensive. Many of the guys in this forum are saying that you can use a motor oil ( 20w-40 I think) and this will work well. I have regular tractor gear oil (85-140) in mine, but it is really sluggish in extremely cold weather, so I'm considering the motor oil myself. I think the multigrade motor oils would have been suggested by Ferguson if it were available then.
Your hydraulics are slow because of the heavy grade oil that you are using, it is also corroding away the bushes and shims etc in the transmission and hydraulics because of the sulphur content of the oil.(all yellow metals) Change the oil to Multi-grade 15W/30 and it will work fine in cold weather. You have not considered the hydraulic system when you added the oil, hydraulics do not like thick oil, they work best with thin oils, but because it also has to lube the transmission and the rear axle, the oil needs to be heavier than a hydraulic oil so you use 15W/30 instead and that caters for everything. We used Multi-grade oils in the Fergusons as early as 1955 and the factory recommended it here in the UK. When the tractor was designed in the 1930's there wasn't any Multi-grade oils, they only appeared here middle 50's just as the tractor was stopped. it was recommended for the 35's though.....John
