blueridge
- Location
- Crawfordsville In
Noise in front of my 42 H Transmission, Took Coupling apart and front bearing retainer off and main drive gear and shaft came out front, and Pilot Bearing bolt and Lock Washer was loose in end of shaft, I mean not even screwed into threads. they are both chewed up some. Also Small gear on main shaft is bad and inside teeth on 4th & 5th gear is bad. Getting ready to pull top off Trans. My question is what does a new or good used bolt and lock washer look like for this? Can someone send a picture of these.
I can get the gears on this web site I think, but don't see the bolt or lock washer. Maybe some one knows a source for the bolt and lock washer also. Thanks for any help you can give. Gene
